H
Need some help on the king cat.All stock what does this sled need to keep up with the other 800/900 out there?
thanks
chris
thanks
chris
Note: This feature currently requires accessing the site using the built-in Safari browser.
A good rider. Most people ask the question the other way around, what do they have to do with their sled to keep up with a King!
You are only an hour away from me. Come up some day and I can show you some of the better things to do with the King. It is a great sled when set up properly. PM me.
SuaveGato sounds like you have a good start. I would only recommend putting a riser on your steering and possibly a steering forward Kit. You can also put a rear suspension drop bracket on it from holz. This puts all the track on the ground.
The steering forward kit is made by Wildchild on here. puts the handlebars 2 in forward.
makes sled more of a rider forward vrs stock.
Risers are a must. I went with OLE riser cause it put the steering straight up instead of straight back plus they are cheep upgrade. around $40
I installed a m7 162 skid on my king cat. you just need 1/4 in washer on the front arm to install the skid. Only reason i put one on there is had sled run into back of my sled. you will still have to put the drop brackets on there. keeps the tunnel away from the track. sled junkies drop brackets work fine as well. one thing with the m skid is you will have less problems with stabbing the track and more usable suspension that is lighter.
Anti stab kit would not hurt especially for peace of mind.....M skid has a different rail than the king on the front of the skid
