Self Made Sno Pro Box
I Took My Stock Air Box Out & If You Look At It There Are Lines In The Top
That Resemble A Triangle's On The Top. I Drilled Holes In The Corners To Leave A Rib Of Material Around The Out Side & Two Ribs That Are The
Dividers Down The Center Of The Box. I Took A Jig Saw & Cut The Top Out Of The Box & Cleaned Up The Fuzzys With An Exacto Knife Then I Bought
A SLP Part # 14-253 18X18 Pre Filter Sheet & Used Weather Strip Adhesive
& Glued It To The Box. Make Sure To Overlap It Just A Little.
Then After Its Dry 15-20 Min I Took My Electric Stapler & 1/4 Inch Stapples
And Stappled The Edges Down & Cut Off The Extra. Then Take The Extra
& Pull Out Your Front Screen In The Hood & Cut A Piece Of Flow Rite To Fit
The Hood Opening & Put The Screen & Clips Back In The Hood So When Hood Is Closed Pre Filter Is Out Front I Have My M7 & M1000 & 5 Freinds Of Mine
Built Like This & They All Love Them Also On Mine The 7 Has Twins & 1000 Has A Single & I Cut Holes In The Side & Front Of My Box & I Have Some Stock Air Intake Screens In The Nose Cone Like Chris Burandts To Get More Air In The Nose 4 FT & I Have Looked Like A Mole & No Bog
If You Want More Info PM Me & Ill Call You.
